13" Subaru Rims on 1000?
Hi Guys. I am hoping for some help. Would Subaru Brumby 13" rims with 175/70 tyres be a good choice for my Datsun 1000 sedan. I have found an excellent set that are cheap but is the offset, wheel spacing, overall diameter and so forth okay. Any advice greatly appreciated. (My 12" tyres are knackered and I am trying to get the car ready for a road worthy in the next few months)
Posted on: 2009/5/5 12:34
Re: 13" Subaru Rims on 1000?
From Darwin NT
i think you will have some trouble with the offset
they would probably be some queer fwd offset
Posted on: 2009/5/5 12:45
current project 4x4 patrol...
From northern 'burbs adelaide
and i think they have a big pcd on the studs
Posted on: 2009/5/5 12:48
Yes, pitch circle may differ.
* Datsun rwd is 4 on 4-1/2 (equivalent to 114.3 mm). In the best English tradition they used an imperial specification rather than metric.
* Subaru 4-bolt wheels are 4 on 140mm, 4 on 100mm or 4 on 4-1/2 (various models)
I think the Brumby/Brat has 4 on 140mm PCD.
Posted on: 2009/5/5 13:57
Thanks guys for all your fast replies its a great help. Looks like I will give them a miss although even just the tyres at $100 for 4 is tempting but I would need to find 13 inch rims. Any ideas on what would be the ideal steel rim - RWD Corolla?
Posted on: 2009/5/6 0:59
I think the ideal wheel will be same offset (30mm) but 5" wide instead of the 4" stockers.
175/70-R13 requires a rim 4.5" to 6" wide. The B210 & B310 wheels is 4.5 inch with 30mm offset. So that's a good choice. The B210/B310 factory aluminum are even better at 5" with 25mm offset.
Not sure how these fit on a B10. B310 wheels don't fit a B110 correctly.
Posted on: 2009/5/6 1:08
From Perth WA
where are u? I have a set of toyota T18 13" rims that are 6" so wider and better looking than stock corolla rims, u could use them with the tyres off the subaru rims. 175 is the best tyre size for a 1000.
Posted on: 2009/5/7 6:35
