« 1 (2)
Re: diffs AGAIN! sorry guys
From Adelaide, Australia
yea but out of all the diffs in the world there has to be one that fits. cutting a diff down isnt really a solution for me. its expensive and if u brake an axel it cost mega $ to get another 1 cut down & resplined. i would rather muck around with different ofset wheels ect than go cutting anything down. it mite sound impossible but so did putting a e15et in my datto but i did it :P.
surly just 47.5mm longer either side with flares should be alright? shouldnt it? :/
there must be like 8 of those diffs down there (common) they come out LSD and its volvo.
Posted on: 2009/5/17 4:07
From BrisVegas
A Bluebird/S12 H190 is 144cm if that helps. Only 3 LSD options available though: CIG, Topgear's awesome Torsens or a plate centre from the US (if they still make them). S12 axles are nigh on unbreakable.
The Dualcab Navara 2WD also has a H190 & is leaf spring. Nothing in common with the BB/S12s though.
Posted on: 2009/5/17 6:18
Gazelle MotorSport
RPJS12 Gazelle - "Big Block" CA20DET
D21 Navara Dualcab - Tow car
http://members.optusnet.com.au/web101/s12.htm
From Albury
Hey Matto
How about a A15 vanette rear end. I think they have a h190 diff which you would be able to get a LSD for. Plus wheel studs would be the same and it would not be any longer than you have been looking at.
Cheers
Bob
Posted on: 2009/5/17 9:39
From Ipswich, QLD
you can run an r31 not cut down with Hyundai elantra 4stud rims with flares, plus you get disc brakes too
Posted on: 2009/5/18 8:36
From Perth WA
I would have thought 50mm oversize on each side would be ok with fwd offset wheels.
Posted on: 2009/5/18 8:46
IF i do end up using the volvo diff do i chane my wheels to suit or make the axels suit my wheels?
Posted on: 2009/5/18 12:24
« 1 (2)
