« 1 (2)
Re: A14 need answers
From Melbourne, Oz
Yep, its useualy ring's but can allso be valve guides and I guess gasket if its only ruptured between the cylinder and an oil galery.
Posted on: 2009/5/18 9:37
"I hav achieved wood"
From Toowoomba, Qld
There will always be some blo-by present even in a fresh engine, its a pretty rough way to check engine condition. like DD said, check your valves for seal using liquid, check the top of your block and the bottom of your head for straightness, if they're fine and the top of the piston also looks fine, put it back together with a new gasket, then comp test it again, if it's still off, get a leakdown test done to check the condition of the rings or put a couple drops of oil into each pot. If the oil raises the comp its usually rings/piston, if it doesn't, it's usually valves.
Cheers Dave.
Posted on: 2009/5/18 9:46
From Melbourne, Oz
aw ya can allso "wet test" buy puting some oil in the cylinder whilst ya test it, If the comp comes up after doing so it would sugest it is the rings.
Posted on: 2009/5/18 9:52
Not too shy to talk
From Northern Rivers, NSW
thanks for the help guys, ill run some more tests and see how i go
Posted on: 2009/5/18 11:11
Now that was some comprehensive feedback aye?!?
Top stuff.
Posted on: 2009/5/18 11:31
« 1 (2)
