« 1 2 (3)
Re: What A series head is this no casting numbers !!
From Melbourne, Oz
pretty sure thats right A14force. ya can go even bigger with reduced Lseries valves, and I'm looking into some 350chev Ti blank's.
Posted on: 2009/5/23 3:25
"I hav achieved wood"
But do larger valves help? Or hurt? If you go too big and get them to close to the cylinder walls the reduce effictiveness. Only a dyno would tell.
Posted on: 2009/5/23 3:33
From Melbourne, Oz
Verry true. Idearly you want the nearest edge of the valve the same distance from the cylinder wall as the lift so you can hav the ortimul radius from the seat to the wall
Posted on: 2009/5/23 3:40
Quite a regular
From Modesto, CA USA
i measured them before i put head on at a friend place. 30mm on exhaust 37mm on intake.
Posted on: 2009/5/23 5:12
Daft Innovations
For ls1 swap parts for 240sx
Add me on Myspace For swap pictures.
Those are bigger than GX valves which were 35/29.
Posted on: 2009/5/23 5:18
From Melbourne, Oz
Yeah there a15 sizes allready
Posted on: 2009/5/23 5:50
Quite a regular
so phuck it no need for l series valves. im not to worried about it. well i went to go autoex the car today and turns out i broke both motor mounts on first run :(
Posted on: 2009/5/23 22:03
Daft Innovations
From Las Vegas USA
The stock 1200 motor mount rubber starts tearing at the top edge, when you rev the motor you can see a 1 then 2MM gap open up.......not long after they fail. Over the last 20 years I've changed 3 sets, mind you here in Vegas the pizza oven weather tends to bake and crack all things rubber and plastic.
Not a biggie to change the mounts, hopefully the next autocross will work out better. I recently aquired some of the Blu-Alu spring retainers (they are for race springs, used to be on the Motorsports catalog) and some tuliped 37mm & 30mm valves.....neat suff.
Tom
Posted on: 2009/5/25 17:49
« 1 2 (3)
