Hilux Diff Conversion
From Mudgee
Im looking at putting a hilux diff under my ca18 1200 sedan. Will the standard drum brakes off of a ute fit on???? If not what brake set up will fit ???
Posted on: 2009/5/21 7:00
Re: Hilux Diff Conversion
From Mudgee
anyone??
Posted on: 2009/5/21 23:17
From pooraka,,adelaide
how about the hilux brakes??
i looked under my house mates and his brakes seem alot bigger than a 1200
Posted on: 2009/5/21 23:26
620 ute -sr20det full irs
vanette-a15 turb
260c- daily
1000 4dr- a15
1000 4dr- project to be sr20
garage 910
From Mudgee
Na the drums are 15" they won't fit in 15" rims
Posted on: 2009/5/22 3:49
From Geelong, Vic
15 inch drums? didnt know there were any 20 ton trucks running hilux diffs lol
hiluxs have 14s or 15s on them stock so the drums cant be too big, think ange had 13 inch steel rims on his hilux diff for the drags
Posted on: 2009/5/22 5:28
From hervey bay queensland
im with you pigdog i thought they had 11"-12" drums depending the model and year.
Posted on: 2009/5/22 5:48
classic not plastic
From ACT
I have one at home I can check. RN40 SR5 Hilux. I plan to use this diff in an SR20 conversion I will be starting soon so if anyone knows if they iz good for dattos pls do tell
Posted on: 2009/5/22 5:55
Now riding dirtbikes:
Lots of A series Datto stuff for sale
From Mudgee
wasn't sure exact size would like to know if anyone has used the old drums though
Posted on: 2009/5/22 6:28
Quite a regular
From Modesto, CA USA
I have a 89 toyota pickup here in the states. it has the 7.5 inch diff with 5 lug yes with drums. it came stock with 14s I have a rb20det in it actually. I put 410 gears in it and rear end seems pretty stout. the rear end housing will need to be narrowed I would think.
Posted on: 2009/5/22 9:21
Daft Innovations
For ls1 swap parts for 240sx
Add me on Myspace For swap pictures.
Not too shy to talk
From Rockhampton Qld
Are you keeping 5 stud Toyota or redrilling/new 4 stud axles,if so r31/s13 discs & calipers probably the go.
Posted on: 2009/5/25 10:32
1200 ute ca18det [in build] , XR6T 314 RKW , FXSTF tractor.
