#1 Master Cylinder Troubles
toydat07 Posted on: 2009/5/27 1:25
i have just installed a r31 skyline diff and disc brakes into my 1200 ute.
i have a 180b master cylinder and the booster is from a BMW323.
the front disc brakes are working fine and the rear are not clamping the disc fully.( the pedel is like a sponge but lines are not leaking)
does anyone know if there a valve in the master cylinder that needs to be removed to allow for disc brakes on the rear? or any other ideas?
thanks
#2 Re: Master Cylinder Troubles
greendog Posted on: 2009/5/27 5:23
yeah i think you have to take master off its in the section where the rear line connects to master,
#3 Re: Master Cylinder Troubles
toydat07 Posted on: 2009/5/28 2:27
yeh i think that will bethe way to go
#4 Re: Master Cylinder Troubles
PIGDOG Posted on: 2009/5/28 2:46
you dont need to take that valve out, ive run my car with a couple of disc/drum masters with discs all round and have not had any troubles...sounds more to me like you need to bleed the brakes again
