fitting 15 inch trx rims
Quite a regular
From sunshine coast QLD
got a set of trx rims for my ute. what do most people do to fit them on the front? mine hit the strut and therefore don't fit, sugestions please?
Posted on: 2009/5/31 2:19
Re: fitting 15 inch trx rims
From pooraka,,adelaide
wheel spacers??
Posted on: 2009/5/31 2:54
620 ute -sr20det full irs
vanette-a15 turb
260c- daily
1000 4dr- a15
1000 4dr- project to be sr20
garage 910
From illawarra, nsw australia
on the front of my 120y im running about 20mm thick spacers
Dont know how similar the 1200 utes are but i imagine the standard wheel offset is the same
Posted on: 2009/5/31 4:33
does anyone know the stud size for a 80's 1200 ute
Posted on: 2009/5/31 10:49
From Geelong, Vic
on stock struts you need spacers
or you can fit larger struts to the car, stanza, 180b, 200b etc.
Sure. They are M12 size, with 1.25 threads.
Btw, B110 and B210 wheels have same offset (+30mm).
Posted on: 2009/5/31 14:03
sorry i meant the pcd i just didnt know how to say it
Posted on: 2009/6/1 7:26
Quite a regular
i've done a rough measure up and i will need around 15mm spacers for them to fit. the thickest spacers i'm told i can buy are 8mm
i think the pcd is 114.3mm
Posted on: 2009/6/1 7:48
Quite a regular
don't reall want to buy bigger struts as the ones i have are adjustable coil overs
Posted on: 2009/6/1 7:49
From Mudgee
How wide are trx rims
Posted on: 2009/6/2 4:27
