Axle Length?
From Nyngan, nsw Australia
Are B120 ute axle's the same length's as each other?
Posted on: 2009/6/2 3:51
living is good,.....
Re: Axle Length?
From Geelong, Vic
yes
Posted on: 2009/6/2 4:14
Re: Axle Length?
Correcto. All 1200 axles are same length RH and LH side are interchangeable.
B110 & B210 axles are the same (H145/H150 same)
H165 ute and H165 B210 axles are same.
Posted on: 2009/6/2 4:25
Re: Axle Length?
Thanks fella's i wasnt to sure as i recived a diff housing with to axles in it looking to same,
thanks cheers rod.
Posted on: 2009/6/2 5:29
Re: Axle Length?
next question: are 120y's and 1200 ute's use the same axle?
Posted on: 2009/6/9 0:14
Re: Axle Length?
Yes: 120Y with H145 diff, 1200 ute with H145 diff.
Other 120Y NO: uses BW diff
Posted on: 2009/6/9 3:40
Re: Axle Length?
thanks there dav, i new you come through, cheers
Posted on: 2009/6/9 3:51
