skimmed head, aaaahhh man
From durban, south africa
hey guys,
i got my head skimmed yesterday, 1.5mm has now been removed. bolted it up and found quite a differance i just need to do some fine tuning and i should be sorted.
i would also like to know, what happens when you have your cam timing 1) 1 tooth advanced and 2) 1 tooth retarded.
many thanks
nicholas
south africa
Posted on: 2003/8/26 6:09
VW chassis
fibreglass body
A-14
280 cam
ported head shaved 1.5mm
extractors with 2inch s/s pipe
webber 38 dgas.
to come........
Dellorto 36 drla
turbo
and then maybe some gas
Re: skimmed head, aaaahhh man
Usually if the timing is off one tooth, it sputters and coughs and doesn't run quite right. Two teeth, it may not even start ...
Posted on: 2003/8/26 6:14
From Sydney, Australia
Shaving the head does alter the timing, it might be time you bought a vernier cam gear, to dialout some the changes to your timing as a result of shaving the head.
Chris
Posted on: 2003/8/26 7:35
Not too shy to talk
From JKL, Finland
Timing changes with OHC-heads but not with OHV.
Posted on: 2003/8/26 13:36
Of course! Thanks for the correction.
I am getting confused with L series stuff.
Chris (The OHV dunce)
Posted on: 2003/8/27 0:08
From NorCalifornia, up by Sac
Hope all goes well. My skimmed head ended up quite rough.
Posted on: 2003/8/27 2:50
Ugh!
Posted on: 2003/8/27 3:13
