pedal box
From illawarra, nsw australia
hi
im currently running an auto in my 120y and its running a pretty large brake booster
now i have done my homework on everything but just wanted to know whats what when it comes to the pedal box
do the pedal box's alternate at all when it comes to no brake booster and brake booster.. also is the mounting any diferent when it comes to swapping the two over
cheers
J
jpg  brake booster.JPG (114.76 KB)
11567_4a36d57e1d8fd.jpg 1199X765 px
Posted on: 2009/6/16 0:13
Re: pedal box
From pooraka,,adelaide
i think the pedal box is the same but the brake pedal might b diff with booster and no booster
Posted on: 2009/6/16 2:49
620 ute -sr20det full irs
vanette-a15 turb
260c- daily
1000 4dr- a15
1000 4dr- project to be sr20
garage 910
Re: pedal box
From northern 'burbs adelaide
nah, they are the same set up as those with a booster have the same push rod end as those with out a booster ... looks like you have a PBR corolla ke55 brake booster and master?
Posted on: 2009/6/16 7:43
Re: pedal box
From Geelong, Vic
pedal box is different, mounting for the booster is different to mounting of the master cylinder obviously. apart from that they are the same
you can modifly a non boosted one to suit a booster, but its a bit harder to make a boosted one non boosted
Posted on: 2009/6/16 9:32
Re: pedal box
I dont really know what the booster is from
so booster and non booster is a diferent rod,? But i can make it into a booster setup using the box i already have?
Cheers for the info too lads,
Jason
Posted on: 2009/6/16 11:49
Re: pedal box
Have a look under the dash where the booster comes through, if it has been modified it will be obvious. Even the earlier non boosted 120Y had 4 bolts going through the firewall. The difference is the brake pedal. For safety reasons you should use a manual brake pedal instead of leaving or modifying the auto one. You just drop the steering column and feed the auto one out then bolt in the manual pedal box. There is a blanking plate on your firewall that has 3 bolts in it which will be removed to fit the clutch cable bracket. It is all a fairly simple conversion.
Posted on: 2009/6/16 12:08
Re: pedal box
ok thanks for the heads up rev, will hopefully be sourcing parts early next week
Cheers
J
Posted on: 2009/6/16 12:26
Re: pedal box
From Sydney
here's a pic of 120y pedal boxes the one on the left is no brake booster type
Posted on: 2009/7/19 7:47
Re: pedal box
Thanks heaps ben thats answered my question completly
Cheers
Jason
Posted on: 2009/7/19 9:04
