help! spring shackle bolts!
From brisbane
i cannot get the spring shackle bolts out, i have tried a search about it but cant find much.
i would like to know whether the bolt itself will come out, or do i need to undo the top bolts and take off the complete shackle plate?
and also, is it somewhat safe to replace the original bolt with a high tensine steel item?
any help much appreciated.
cam
Posted on: 2009/6/21 13:12
Re: help! spring shackle bolts!
From Geelong, Vic
easiest to take the whole shackle off, why do you want to replace the bolt?
Posted on: 2009/6/21 13:16
From brisbane
i need to replace it because the tramp rod setup im making at the moment needs a slightly longer bolt.
Posted on: 2009/6/21 13:20
From Geelong, Vic
im very much doubting you will find another bolt the same shape, but you do know that the top shackle bolts are longer than the bottom ones right
Posted on: 2009/6/21 13:24
From brisbane
ahhhhh i did not think of that.
that still leaves me with the problem i have of getting the bolt out though.
Posted on: 2009/6/21 13:28
The 3 bolts are pressed onto the inside plate and come off as a unit, once off you can knock the bolt out and redrill it and the outside plate to whatever size you need.
Posted on: 2009/6/21 22:25
