which handbrake cable for 1200 coupe
From Vanderbijlpark, South Africa
which handbrake cable will work on a 1200 coupe? can't seem to get one from local parts dealers. any other model datsun that will work, the long on ethat goes to the back
Posted on: 2009/7/8 7:50
93' Nissan 1400 a15 60a (daily)
82' Datsun 1400 ute (sold)
73' Datsun 1200gx Coupe (sold)
Re: which handbrake cable for 1200 coupe
From northern 'burbs adelaide
where are you located? which section do you need (front or back or a whole one)? either look around at wreckers or go a universal one and cut and shut it to suit
Posted on: 2009/7/8 9:20
Which handbrake cable will work on a 1200 coupe? Any from a 1971-1973 sedan, wagon or ute.
Posted on: 2009/7/9 5:34
From sydney australia
You could also try the handbrake cable from a B210 (120Y, B210, Sunny) as they are the same rear track as the 1200's. The B310's (Sunny,210,whatever) are a bit wider & I don't think the cable would work properly.
Posted on: 2009/7/10 0:47
From Los Angeles,CA
I got a brand new one from www.rockauto.com. $25 USD
Posted on: 2009/7/11 0:49
