« 1 (2)
Re: Wiring Help! WITH ILLUSTRATION
Alternator Wiring
F = Field
N = lamp signal
With an SL type, S corresponds to F, and L to N.
In other words, the connector for Hitachi SL with t-connector is exactly the same.
I don't think you can damage the alternator by getting the SL or FN wiring mixed up (it may blow a fuse, or just not work). However if you connect the battery backwards, some alternator will be damaged.
Posted on: 2009/7/20 19:00
Edited by ddgonzal on 2009/7/20 19:39:40
From Lisboa-Portugal
Thank you Master DD once again! You save my day!! I will cut the T connector and wire it up in the SL connector.
Thanks
Posted on: 2009/7/20 19:28
« 1 (2)
