Rack and Pinion into 1000 coupe
From Sydney
hey guys well after crumbling to the pressure of my mates convincing me to put a rack in my 1000 i was just wondering if anyone has every toyed with this idea before and what ideas did you come up with. Also what rack would you of used. Ohh and if some one would be so kind to take a measurement from the steering arm to other steering arm it would be much appreciated as my font end is in bits due to putting my brakes together and other stuff up there ;)
Many thanks Tom
Posted on: 2009/8/3 12:39
Re: Rack and Pinion into 1000 coupe
From Perth
Why would you want too ?
Look at Camira if you have to
Posted on: 2009/8/3 12:48
From Sydney
big heavy auto is in the way where the draglink would go plus i need a collapsable column now as the car has to get engineered and the engineer doesn't want the old solid column in it
Posted on: 2009/8/3 12:52
Datsun 1500 sr20det
From Perth
Good luck
Your on your own with this one
Doublt its ever been done
My 100 racecar had a LJ Torana rack... but... it was a tube chassis
I don't knopw what you will find that will bolt to the existing Xmember
Move the engine back
And why do you have a big silly auto in there anyway ?
Posted on: 2009/8/3 13:17
if its just for a collapsable column for the 1k, use a 1200 one as they pretty much bolt up, make sure you keep the indicator setup as it is slightly different but connects strait into the original wiring.
Posted on: 2009/8/4 1:09
From Freo
agreed, why change from a good thing,
and if the 1200 column goes in.. easy work..
Posted on: 2009/8/4 1:17
A15 PSI Project Motor
'72 CB750k,
From Sydney
its good to know the 1200 column fits i might look into it also are new tie rod ends and idler arms and drag link available as mine are stuffed and dont wont to put #OOPS# stuff back in my car as every thing else is new.
Posted on: 2009/8/4 14:01
Datsun 1500 sr20det
From Perth
Nope... all those parts are gone
Same with upper balljoints and most of the bushes
Unless you go spring for Nissan genuine prices
Posted on: 2009/8/4 14:21
you can get yours recoed and use the polyurethane replacements also.
Posted on: 2009/8/4 15:15
