Fuel Pump problem
From Sri Lanka
Hi Guys,
last Saturday I was traveling to hill country side ,just before my destination suddenly my car stooped, tried to start but did not then i was paddling my throttle for some time and could start the car and again same think happened,actually it was a problem with my fuel pump that did not deliver enough fuel to the carb, i had to increase the wight of the fuel pump handle that connects to the engine to increase the pressure from it ,fortunately i was closed to my mechanic,
thanks
regards
sumith
Posted on: 2009/8/17 8:06
Re: Fuel Pump problem
From Melbourne, Oz
Maybe check your tank for rust. I had a similer problem were it was like it ran out of fule every now and then, and I replaced the pump and all the lines and allmost gave up on the sidroughts I had on, and then some old bloke sed probly got rust in the tank like he was the all knowing oz. and he was right the bastard! HAHA!
Posted on: 2009/8/17 8:21
"I hav achieved wood"
Hi Sumith,
Glad to hear you got it fixed. It sounds like you had a pre-1974 fuel pump on an 1974-up engine.
As a note of warning, never paddle the throttle of a warm engine. Depressing the throttle squirts raw gasoline into the intake manifold, and can wash out the cylinders of a warm engine.
When the engine is warm, hold the throttle slight open (depress pedal about 1/2 down) and try to start the car.
Posted on: 2009/8/17 8:29
From Sri Lanka
Hi ddgonzal
If my fuel pump fails again and again my mechanic said , i may need to go for electric fuel pump which will cost 20 U$$ , but i don't know how reliable those . are you using electric fuel pumps or mechanical ones ?
thanks
regards
Sumith
Posted on: 2009/8/17 8:56
The most reliable are the original Datsun fuel pumps (mechanical) which have many bolts around the top. I am running this 1972 pump.
$20 may buy a used pump. If it is $20 new, it is a cheap pump, beware. In USA, electric pumps are $40-50 USD and more.
Posted on: 2009/8/17 9:29
