A14 not firing (elec dizzy).
From Gawler, Sth Aust
My b110 is not starting, I checked the coil lead with a test light and found there was
no pulse but there was power at both + & - sides of the coil.
I may have accidently connected a wire some where I shouldnt have when trying wire the coupe tacho. It's all wired normaly now but I think I damaged something!?
I might go look into a new coil and resistor. what would people recommend? Is there such a thing as to much spark?
Looks like not driving it to work in morning!
Posted on: 2009/8/23 12:00
72 B110 A14
71 B110 A12a (Parts)
06 380 VRX
Re: A14 not firing (elec dizzy).
You sure there is no spark at the plugs?
There should be wiring diagrams in the wiki that you could use for reference.
Posted on: 2009/8/23 12:05
From Bathurst - NSW
Elec Dizzy should need 12v to the positive side of the coil, no ballast resistor.
Remove your tacho wiring, check your fuses.
Posted on: 2009/8/23 13:00
From Sydney, Australia
it's unlikely you've damaged the coil or ballast resistor.
More likely a fuse.
Posted on: 2009/8/23 13:36
All interior fuses are fine and I didn't think there was any in teh engine bay. The tacho wiring is removed. That's why I'm confused.
The test light showed power to the negetive side also that's why I think I have an issue with the coil. But no power to the plug lead plug.
Posted on: 2009/8/24 0:55
72 B110 A14
06 380 VRX
That's correct. The coil has an internal wire connecting the + and - terminals.
What you should do next? Carefully follow the Nissan tests. If you have the matchbox distributor, test procedure is here.
Posted on: 2009/8/24 4:13
I don't have that distributor I think mine is an a12 dizzy with electronic ign in place of the I did a few test last night and have roughly narrowed it down to teh coil. Ihave ordered a new
one and will pick it up tonight.
Fingers crossed!
Hopefully this might help an underlying issue I have with a misfire once the car is warm.
And thanks for the imput guys especially ddgonzal.
Posted on: 2009/8/24 22:25
72 B110 A14
06 380 VRX
Quite a regular
I had this issue with my e15 distributor conversion, chased it around for ages.
As it turned out, I'd wired it wrong, I put the 2 wires coming from the dizzy to the + and - on the coil.then an active to the positive side of the coil, then a earth to the - side of the coil(to the body) WRONG
the - side of the coil cannot be earthed, or this will take the fire signal away from the coil, hence no spark.
just check that on yours.
Posted on: 2009/8/25 9:37
