What diff??
From Perth W.A
i got a 120y coupe with an a14 and standard little jap diff that is wanting to go i think
the car has a big exhaust and is soon to have extractors webbers and some cam work so what do you guys suggest?
Cheers aaron
Posted on: 2003/9/18 4:00
120y Coupe
120Y coupe Race car (SOON)
120Y Sedan for the Lady
Re: What diff??
From Melbourne, Australia
some/most 120y's have a borg warner diff, if thats not hwat you already have, it should be pretty cheap and almost a straight swap over, otherwise a h165 out of a 1200 ute or if you can live with wider track (flares or fwd offset rims required) a h190 from a vanette
Posted on: 2003/9/18 4:22
1200 Coupe Weekender
1200 Coupe Rallycar
1200 Coupe Wife's Daily
1200 Coupe Project A15ETT
Re: What diff??
From Brisbane, Australia
the coupes were fully imported and have the jap Hitachi diff. Sedans were locally built and have the much larger and stronger Borg Warner, but in the same 3.89 ratio. You will also need to grab the tailshaft, but that a good thing as well with larger unis, and it will all bolt straight in. Take the rear section of handbrake cable too, just to make life a little easier.
You can also use KE30 to 55 Corolla diffs which are the same BorgWarner unit, with 3.89, 4.1 or 4.3 ratios and 3" wider track. You need the 120Y BorgWarner tailshaft and diff flange, and it will bolt in. hooking up the handbrake will cause a few headaches. That's what I use in my race car, so I didn't bother with the handbrake setup - just removed it all to save weight. Also remember that toyotas use a different thread wheel studs...
Posted on: 2003/9/18 4:52
Re: What diff??
From sydney australia
just wondering if the australian built stanza used the same centre as all these toyotas,as the stanza is supposed to be a 3.7:1 diff ratio.
Posted on: 2003/9/18 4:55
Re: What diff??
From Perth W.A
did some of the h190's come with LSD centres or am i thinkning of the wrong diff?
Posted on: 2003/9/18 5:12
120y Coupe
Re: What diff??
um yeah in about 500 government issued blueys, no markings to help you find one either, good luck
Posted on: 2003/9/18 5:30
1200 Coupe Rallycar
