ca18de deck height and other info
Just wondering if anyone knows the deck height of the ca18de or det?
also rod length and pisont compression heights?
regards, dave
Posted on: 2009/8/25 14:39
Re: ca18de deck height and other info
From Christchurch NZ
rod length is the same as a14/15. I'd have to measure the crown height tommorrow if I remember. you know they have a kick arse dome aye?
Posted on: 2009/8/26 8:52
Forced Induction!
From perth
rod length 133 +/- 0.05mm
piston pin hole 19.987 - 19.999
pin 19.989 - 20.001mm
deck height 204.75 - 204.85mm
pin height ?
all from genuine nissan manual (DET)
Posted on: 2009/8/26 11:58
Thanks guys
so rod stroke ratio with 83.6mm stock crank is 1.591
piston comp height must be 30mm like the ca20?
Posted on: 2009/8/26 15:31
