« 1 (2)
Re: SLAM1024s Turbo A12 update
From Perth
I got 106 hp at the wheels @12psi with a stock A12 turbo setup mine is a round port standard carby manifold modified with injector bosses welded to it and a 65mm throttle body off a toyota camry my intercooler looks the same size as yours i think you should get around the same power with the right carby
Posted on: 2009/9/10 23:13
From Lethbridge, AB, Canada
Thanks man,
Yeah Im hoping that it will make a good amount of power.
My carb is pretty greedy on fuel at higher rpms because of the tapered needle so hopefully it will help me get my hp up there.
if i could get 106 to the wheels that would be awesome!
Posted on: 2009/9/11 1:23
'73 Datsun 1200 Sedan Turbo A12
UPDATE---
Yesterday:-
-Finished fabricating all intake piping
-Polished all S/S piping
-Modified and mounted intercooler
-1/2 Mounted Radiator
-Mocked up throttle cable positioning
Tomorrow morning:-
-Fab more mounting brackets for rad
-Modify thermostat housing
-Make extra parts for throttle cable mount
-Fab additional parts for plumbing in rad
Sunday
-Mount electric fan
-Install all parts that I just fabbed up
When I get my carb rebuild kit I will then rebuild carb and then slam the lid because I will be done with the mechanical side of things
Then on to mounting seats and finishing interior.
I hope I can keep up this momentum!
Posted on: 2009/9/12 7:01
Here is the little adaptor I made up to connect the throttle cable to my SU carb -- installed.
Today
-Installed throttle cable
-installed rad
-modified thermostat housing but I screwed up and have to change the orientation of the spout again
Its coming along well
jpg  throttle cable.JPG (172.65 KB)
523_4aac3a03943b9.jpg 960X1280 px
Posted on: 2009/9/13 1:17
This will be a very interesting build using the better A series engine over
the one the factory su turbo setup it was designed for.
Very neat and clean install keep it up.
Posted on: 2010/5/20 5:23
« 1 (2)
