1200 ute axle tramp. what have you done to stop it
From brisbane. waking up the neighbours with the brap
wassup guys.
ive got a datsun 1200 ute. have some serious axle tramp. ive got all new bushes in the rear. new spring and new shocks. i have converted the rear end to hilux diff. had an extra leaf fitted to the leaf spring and still wants to axle tramp.
looking to see if anyone has the same issue and what they had done.
Posted on: 2009/9/14 1:14
13b turbo datsun 1200 ute. (WARZ ON)
www.maddat.com.au
Re: 1200 ute axle tramp. what have you done to stop it
From perth airport
did it do it befor the big diff went in ?
wat kind of power does your rota have ?
wat kind of tyres are you running ?
have u though about tramp bars ?
Posted on: 2009/9/14 1:49
perth airport parking
Datsun 1200 ute A14
yeah it done it before i put the diff in.
my car has been off the road since the start of the year. ive done everything to the car. engine, drive train, rear end. it makes between 200 and 250 hp
tyres are just street tyres.
if i nail it in 3rd gear it will tramp.
im thinkin of putting a caltrack in.
looking to see if anyone has done so and where to get one from
Posted on: 2009/9/14 2:38
www.maddat.com.au
From Brisbane
can you weld? a guy up here in brisbane make sprint car chassis, he did rods out of chrome moly for me, the rest is a machined solid steel bush and laser cut 3mm plate steel or the other parts
Posted on: 2009/9/14 5:08
AWD the way to go
From Melbourne AUS
caltrack setup will sort this out. i did a home made caltrack setup for my ute and it works really well.
Posted on: 2009/9/14 6:02
1973 B110 A12
From Melbourne, Australia
gee that rear end must be stiff... you sure the whole ute isn't bouncin up and down
Posted on: 2009/9/14 8:46
1200 Coupe Weekender
1200 Coupe Rallycar
1200 Coupe Wife's Daily
1200 Coupe Project A15ETT
nah buddy its axle tramp. suspension isnt that stiff. it done it with the a12 before i touched the suspension what so ever. ange do you know anywhere to buy a caltrac.
Posted on: 2009/9/14 10:08
www.maddat.com.au
From Brisbane
I had a half rear leaf put it, from just behind the diff the to front... Helped big time, it still tramps a little when you have alot of grip. (really only when I was doing a skid at the drags) So I'm goin to put another half leaf in and that should sort that out. At a $100 a go it's nice and cheap
All else fails up the power so it can't get grip and it won't tramp
Posted on: 2009/9/15 0:40
If you want more inches, stroke it
From sydney australia
Do you have rubber or urethane bushes in it? The Sunny Coupe I race was axle tramping until I fitted urethane bushes. I changed springs, shocks & tyres until I remembered that I had nolathane bushes in my old Sunny. All my 1200 race cars had the urethane bushes, too.
Posted on: 2009/9/15 6:56
From Adelaide, Australia
Common problem with any leaf spring rear, If the shocks are new monroe or gabriel gas they are too hard and not absorbing any of the tramp, especially in a ute with no weight in the rear.
Try some good quality oil dampners, tokico, koni etc or kyb oil/gas assist are well priced also.
Posted on: 2009/9/15 7:11
cheap + fast = disaster
fast + reliable = expensive
cheap + reliable = stock
IPRA Build
