Torque spec for SSR alloy wheels on Datsun 1200
One of my bolts/threads was stripped on the rear of the 1200 pickup.
What's the recommend torque spec? For stock steel wheels it is 65 ft-lb. I wonder if I should use the same for the alloys, they have a flat type nut, not tapered.
like this:
Posted on: 2009/9/30 5:04
Re: Torque spec for SSR alloy wheels on Datsun 1200
From Geelong, Vic
id say you would use the same specs, as the specs are for the stud/nut not the type of wheel you are using
they dont need to be done up stupidly tight, and only usually get wrecked when someone comes along with a rattle gun and just goes at them flat out...like tyre joints do
Posted on: 2009/9/30 5:16
correct, i had to chisel one off a set of hotwires one time, also another time had to cut the nut off with an angle grinder, not fun, then had to chisel the last few mm to get it off. not fun replace wheel studs i find.
And my tyre guy always wonders why i insist doing them up by hand my self. been stuck in the middle of nowhere when you cant remove a wheel nut? i have, not nice.
Posted on: 2009/9/30 11:27
From Geelong, Vic
yeah not everyone has a half meter long breaker bar and a bit of pipe to undo nuts after tyre guys have been at them
Posted on: 2009/9/30 11:35
From Perth
I use 70 ft-lb on my panasports.... i'd suggest about the same.
Posted on: 2009/9/30 12:32
Strip it, then back it off half a turn!!
Posted on: 2009/9/30 13:45
From Mildura, VIC
id like to know that too. I jus got some alloy nuts for my simmons... I was doing the stockies up 2 90...
Posted on: 2009/10/1 0:21
I'm going with Nissan's torqe spec: 56 to 65 lb-ft. I don't want another stripped bolt.
Posted on: 2009/10/1 2:29
