« 1 2 3 (4) 5 6 7 ... 42 »
Re: 1200RallyCar - My road car rebuild - 1200 coupe
From sydney australia
With the standard steering arm, the two holes for bolting the arm to the bottom of the strut & the hole for the balljoint are all the a line ie the centres all line up. With the 200B steering arm, the hole for the balljoint is not in line with the other 2, it is offset towards the car.
So when the parts are all bolted together, the bottom of the strut is further out with the 200b steering arm than it would be with the Stanza/Sunny steering arm. this is where it gets the increase in track width & negative camber.It's like fitting longer lower control arms but a lot easier. the spacer shown is for cars with short struts. Some are so short that the tie rod end is out of parallel with the lower control arm. When the wheel hits a bump, the wheel will physically turn & steer the car without any input from the steering wheel. makes for a twitchy car,usually under brakes. the spacer is used to get the steering arm lowered & get the lower control arm & tie rod end back parallel.
Posted on: 2009/8/29 5:09
From Melbourne, Australia
thought i'd add an update,
we have given it a good going over, fixed up a lot of patches that needed a bit of work to get them nice and straight.
we have re-sprayed with white primer again and it looks much like the last photo still
Have also done some test spraying of a couple of spare gaurds mucking around with colours. I have found the colour i am after and am going to use a pearl to highlight the body lines of the car... with some good weather it should be coloured up this or next weekend
I also have found a badge that i have been searching for for some time, with my custom plates and hopefully i can get my bumpers powder coated, im getting a lot of bits ready to complete the look im after
getting excited...
still need to find some 200b steering arms and sort out my interior. hmmm theres lots to do even after the colour hits it
Posted on: 2009/9/29 9:30
1200 Coupe Weekender
1200 Coupe Rallycar
1200 Coupe Wife's Daily
1200 Coupe Project A15ETT
From Geelong, Vic
im running 200b steering arms in my car
dont think its quite a 15mm increase...would have thought more like 5-10mm
ive also got adjustable LCAs, so the steering arms are more for brake disc clearance now than anything else
also really need to make up a spacer for the balljoint as the taper of the 200b steering arm is slightly more than the stanza balljoint
Posted on: 2009/9/29 9:41
yay, hit it with some colour today, unfortunately the gun dripped on to the bonnet so we didnt get to hit it with pearl. have to wait for the paint to dry so we can sand the drips out nicely, but we will sand the majority of the colour coat now before we pearl it to hopefully get a better finish that way anyway, enjoy the pics
Posted on: 2009/10/3 11:54
1200 Coupe Rallycar
Posted on: 2009/10/3 11:57
1200 Coupe Rallycar
it looks better in person than the pics look
SO BRIGHT :)
Posted on: 2009/10/3 12:37
Car free
looks like 1200 grit sand paper now, like my color almost... nice
Posted on: 2009/10/3 12:47
not like some hack of a spray job the old owner gave it :)
Posted on: 2009/10/3 13:52
Car free
From SE Melbourne
Who does your painting Mike...that's looking pretty pro from here!
Posted on: 2009/10/5 10:44
Mildman, Datsunless
hey ben its a mate of his brothers, his name is andrew
he has sprayed the rally car to
and mick brothers 4x4
they all look sick
Posted on: 2009/10/5 10:49
Car free
