Turbo ??? help for CA
From sydney
I'm looking at upgrading my turbo on my CA sunny.
i can get a GT35/40 with a .84 rear wheel. Will this be to laggy.
Posted on: 2009/10/1 8:12
Re: Turbo ??? help for CA
From Brisbane
I'd say it will be... By the time that monster spools up every one else would have gone already
Posted on: 2009/10/1 10:12
If you want more inches, stroke it
From Cape Town, ZA
That is a bit big!!
What is your goal or reason for upgrading your current turbo?
Posted on: 2009/10/5 12:12
From Sydney, Australia
Find someone with a real fast CA (with similar head mods) and use the same turbo.
If you don't know anything much about turbos..this is how I'd proceed.
I had a Garrett 440HP GT turbo with 0.86 rear.. was too big for CA.
Your choice is even bigger.
Posted on: 2009/10/5 13:10
From Brisbane
Isn't the 35/40's off the xr6 turbos? Anyways... Yeah it depends on what you want it to do...
I have a 25/60?? (I'll have to look it up) on mine and it spools up nice and quick, so you stomp it and it's there and it pulls right through... Any bigger will take longer to spool up obviously depending on mods
Posted on: 2009/10/5 13:23
From Cape Town South Africa
The only way that combo would be able to spool is if you run major loads of NOS. So unless its a full on drag car go smaller and enjoy a responsive turbo.
Posted on: 2009/10/5 14:53
Racing started the day the 2nd car was built!
From mandurah
ive got a chinese turbo (came with my motor)and im quite happy with it. it comes in fairly low and lasts trough out the rev range
Posted on: 2009/10/8 5:07
77 1200 ute
77mm bore a15 ,12:1 comp
ported and reconed h89 head
MSD 6al2 with 2 step limiter
4speed 60a box
hd clutch
2 inch exhaust
locked 4:11 ute diff
