Browsing this Thread:   8 Anonymous Users
« 1 ... 934 935 936 (937) 938 939 940 ... 1777 »
Re: PERTH BOYS.. GO THE DATTO
From perth airport
lol n u wanted 2 do a wrx running gear convershion lol
Posted on: 2009/10/10 10:51
perth airport parking
Datsun 1200 ute A14
From Perth WA AUS
That wont fit!
Posted on: 2009/10/10 10:52
Datsun 1200 2Dr sedan.
From Albany, Perth Australia
yeah but thats a bit different jordy...1200 psrts are meant to fit 1200's without changing anything....my #OOPS#ing arse
Posted on: 2009/10/10 10:53
1200 Smerf Mobile
what wont fit?
1200 Smerf Mobile
From perth airport
u pull the clutch fork then put the cable on ? or hook up the gear box end first then pedal
Datsun 1200 ute A14
tried all the above...but you cant pull it anymore as it goes through the gearbox and the cable runs out before you can get there...
Posted on: 2009/10/10 10:55
1200 Smerf Mobile
From perth airport
its not that hard i got my a15 in the thou with the toyota box in under a hour same has joels coupe . u must be doing somethin wrong
Datsun 1200 ute A14
From Freo
mabee he put in the wrong bearing carrier.. ooops..
Posted on: 2009/10/10 10:56
A15 PSI Project Motor
'72 CB750k,
tis the wrong cross member which stuffed everything up...
1200 Smerf Mobile
and the wrong engine mounts me thinks
Posted on: 2009/10/10 10:57
1200 Smerf Mobile
