(1) 2 3 »
A14 ENGINE STARTED!! Thank you all!!( with video)
From Lisboa-Portugal
After months of (slowly) building up my A14 finaly came the time to turn it on. I wasn`t expecting firing up at first attemp but now after a few tries it didn`t start yet. I think the problem is electrical, and the current is not reaching the spark plugs. I made a few modifications concerning the electrical parts:
Alternator: internally regulated one with the jumper wire "trick".
Distributor: Electronic dizzy (Mal`s dizzy).
My suspect is the dizzy because the original wiring loom in my 120y got a wire that now is no longer needed in this dizzy, i onlu connected the two wires of the distributor to the positive and negative side of the coil and left this wire unpluged. Could this be the reason?? where do connect this wire now.
Thanks in advance for all!!
Posted on: 2009/10/28 11:10
Edited by Bandit_blues on 2009/10/29 15:31:34
Re: Help me start my A14!!!
From SE Melbourne
I remember having trouble first time starting my A14 too - I used the troubleshooting guide (now in the wiki) it was a great help - narrowed it down to dizzy.
It's really good at ruling out potential problems.
http://datsun1200.com/modules/mediawi ... _Troubleshooting_Overview
Posted on: 2009/10/28 12:02
Mildman, Datsunless
From Adelaide, Australia
+ to the coil can help
Posted on: 2009/10/28 12:07
parts needed: GX air filter box. for sale, stanza steering wheel, 1000 gloveboxes lids
Ok, now i made some progress. The engine is now sounding more like an engine, the energy is reaching the plugs now, but i`m now having another problem. The engines is A14 but the carb is from a A15, and it seams like the carb is floding the engine, is there any way to reduce the quantitie of fuel?
Posted on: 2009/10/28 12:57
From Albany, Perth Australia
what carbies are on it...need to turn the fuel mixture down and airflow up
Posted on: 2009/10/28 12:59
1200 Smerf Mobile
when i start the engine the carb send some kind of smoke through the top of the carb, I got a electric choke carb from a vanette. How do i turn the fuel mixture down?
Posted on: 2009/10/28 14:57
Now when i start it and hold the acelerator pedal down it seams to start, but when i release it it goes down again.
Almost there, i can feel it...
Posted on: 2009/10/28 17:16
So you solve the starting problem? It is now starting?
A15 carburetor will run just fine on A14. But as with any carburetor you need to adjust the idle speed and mixture. Just follow the standard procedure in your repair manual. You can use the very same steps as for A12 carburetor.
Posted on: 2009/10/28 18:02
it didn`t start yet, it sounds like is almost staring but it doesn`t.
Posted on: 2009/10/28 19:10
From Townsville, Qld
2 things to remember
1. did you get the spark plug lead order right?
2. is the basic timing in range?
Posted on: 2009/10/28 23:54
(1) 2 3 »
