sticky clutch pedal
From illawarra, nsw australia
hey guys,,
the last few days i have been noticing my clutch pedal is sticking at a very annoying point,
where the car is moving fast enough and i can ride the clutch ( i reely hate saying i have to ride the clutch )
or i can let it go that extra bit more and it jumps out more then what it should and causes an very unsmooth launch
and this is more noticable with hill starts.
i have had the clutch pedal out of the car and cleaned and greased the bushes, i poored oil down the cable but its still reely annoying me,
its the last thing i have to iron out before i get my p's then its just a car to get in and drive
so has any body come across this and what have they done to make it better
is it possable the bushes are worn? i might have another set in my datsun box of goodies
as always thanks alot for any help
Jason
Posted on: 2009/10/30 11:27
Re: sticky clutch pedal
From south coast nsw
i had similar problem after i put my 60series 4speed in,only happened on first use of the clutch each day that was it.? i used the a12 flywheel and 60 series fork i think.i should of used a15 flywheel i think, i havent pulled it apart yet to see wats going but.maybe pivot point on the pedal is incorrect?somehow?you have done alot of work to convert it, maybe just triple check everything.
Posted on: 2009/10/30 11:58
If the pedal was working fine a few days ago, and this just started happening then you must have the right parts... in the past people said the cables can go bad. Maybe you can swap a spare cable in to see if it improves.
Posted on: 2009/10/31 3:17
