How easy to Remove Temp Sending Unit from A series ?
From Sri Lanka
Hi Guys
Can any one tel me is it possible to replace my Temp Sending Unit from A 12 engine by my self or do i need to take it to the Mechanic ?
Thanks
Regards
Sumith
Posted on: 2009/11/3 5:20
Re: How easy to Remove Temp Sending Unit from A series ?
It is very easy. Use a six-point socket, a deep one and simply remove it.
It is the one with yellow wire
Posted on: 2009/11/3 5:44
From Cape Town, South Africa
I'm sitting with a head at home that the heat sending unit is jammed, I have tried everything, next step will be to take a drill to it.
Posted on: 2009/11/3 6:37
Project Build: http://datsun1200.com/modules/newbb/viewtopic.php?topic_id=45104&forum=9
Don't find a problem, find a solution!!!!
www.race-tech.co.za
have you tried to tighten it a little first. Try a breaker bar.
Posted on: 2009/11/3 6:40
Car free
I got the nut out that hold it in place, but it is the physical unit it self that is stuck, probably from all the years of dirt and rust.
Posted on: 2009/11/3 6:50
www.race-tech.co.za
What about vice grips, tap it in all directions and wiggle it out. You will need to replace it afterwards.
I've seen tight ones, but so far they always came out with a bit of work.
Posted on: 2009/11/3 7:07
wat about taking the thur housing off and take thur off and try knock it out from bottom
Posted on: 2009/11/3 7:15
Car free
