Browsing this Thread:   3 Anonymous Users
(1) 2 3 4 5 »
Weight of a 12a rotary?
From Sydney NSW
Does anyone know the weight of a 12a rotary engine? I have heard many times about its small size and light weight, but i cant find what it actually weighs! Any ideas? Thanks
Posted on: 2009/11/2 4:43
Re: Weight of a 12a rotary?
From Griffith
Hey mate im not sure of the weight but have a look on www.Ausrotary.com
Posted on: 2009/11/2 4:56
From Melbourne AUS
i dont know how much they weigh (id be intersted to know aswell), but im guessing about the same as an a12.
gearbox is a different story though, mazda box probably weighs at least double that of the datto 4spd.
my ute was 40kg heavier all up post conversion.
Posted on: 2009/11/2 7:19
1973 B110 A12
Quite a regular
between 100kg and 120kg i believe
Posted on: 2009/11/2 8:01
From Perth
Found on a rota site
mazda 12a rotary with transmission, flywheel, clutch, starter, intake, carb, alternator, coil packs, all required wiring, homemade exhaust header, as pulled from a running car (eg, I could have started the motor on the scales if I hooked up 12V) was 375lbs.
Posted on: 2009/11/2 9:49
From Sydney NSW
cool thanks guys thats exactly the kind of info i was after, and 40kg heavier is not much for the power bump if you had one of these. At least if the extra weight was in the tranny its positioned where it can give some good balance
Posted on: 2009/11/2 11:42
ca18det eats a 12a for a snack in the conversion, weight and performance dept.
Posted on: 2009/11/3 12:17
Are you rotor-ing a 1000 eFunk?
Posted on: 2009/11/3 13:05
From brisbane. waking up the neighbours with the brap
well a c18det should eat a standard 12a rotary.. if it was 12a pp or 12a turbo the rotary would smash the ca18det. as for how it handles. depends how you do the convertion.
Posted on: 2009/11/3 22:56
13b turbo datsun 1200 ute. (WARZ ON)
www.maddat.com.au
Yes, a modded CA18DET beats a stone-stock 12A rotary.
But the 12A is lighter
CA18DET - engine alone: 282 pounds
CA18DET 5-speed: 85 pounds:
CA18DET w/o all acc. but with gearbox: 367 pounds
12A, all acc. & gearbox: 375 pounds, all the weight down low
add an alternator to the CA and that's 377 pounds...some of the weight up high, and more forward too
Look like the 12A beats CA18DET for weight!
Posted on: 2009/11/3 23:52
(1) 2 3 4 5 »
