A Series Works Carbies & Extractors
From Perth WA AUS
Datsun A Series Works Carbies & Extractors A$1,200.00 (inc)
Hard to find Datsun 1200GX Twin Sidedraft 44mm Solex works cards and 2 piece extractors.
http://www.swmotorsport.com/
Check the specials/clearance tab.
Posted on: 2009/11/12 11:59
Datsun 1200 2Dr sedan.
Re: A Series Works Carbies & Extractors
From australia tasmania
wow, no offence to them fella's but damn they are pricey!
Posted on: 2009/11/13 1:52
old skool cool...
www.shakotangarage.com
They've been there for a while so maybe you're right Akina.
But considering they're a complete bolt-on, one-off set, they aren't too badly priced.
Posted on: 2009/11/13 5:30
From Perth WA
those will end up in speedway for sure as they need to use the original datsun options.
Posted on: 2009/11/13 5:47
datsun 1000, Its not the size its how u use it.
From sydney australia
Thats Stewart, always been slightly pricier, but most of his customers don't mind. Those 240z & 260z's in the header are for Historic Rallying in Europe, he also did 3 180B's for the Safari Rally a few years ago. I would recommend Stewart as a source of parts & information. As an aside, if you go to the engine parts section of the menu & look under the camshaft subsection, there is the Nissan factory 70 degree cam grind for $176. You can also get a 37/70 competition/road grind & a 54/86 competition grind,which are Wade Cam grinds. Under pistons rings & bearings there are flat top A10 pistons for $138,A12 pistons for $102, A14 pistons for $129 & A15 pistons for $116. These are probably stock replacement pistons, but the prices seem ok.
Posted on: 2009/11/13 9:49
Speaking of Stewart, he actually called me in PNG to confirm some dimensions for parts I purchased from him. I thought that was pretty damn good of him.
There was a picture up of these a while ago. From memory they are the old-school type Mikunis similar to the set Connor had for sale a while ago.
Posted on: 2009/11/13 10:36
From Perth WA AUS
I thought the price was pretty good.
Posted on: 2009/11/13 12:14
i ment bit pricey in general, just looked at the other items on there.
Posted on: 2009/11/14 4:36
old skool cool...
