cadet 1200 coupe
Quite a regular
hey, just thought i would put up some pics of my 1200 coupe! i had another project build going on here when the car had a 12a and 6speed in it so it may look familiar! after ALOT of thinking about what i wanted out of the car and how i wanted it to perform i decided to ditch the rotor and put a ca18det in it! at the moment the motor is standard with aftermarket exhaust manifold, T28bb turbo, adjustable cam gears and 450x300x76 front mount intercooler. behind the motor is a 5 speed with short shifter! the body has been taken back to bare metal and all rust and dints repaired! it sits in primer so i can test fit everything before it gets painted! have a r31 diff being shortened and a r31 fuel tank to go in! have big plans for the motor but thats a bit down the track yet!
jpg  datoooo.jpg (32.39 KB)
10864_4b08d44599c63.jpg 448X336 px
jpg  datto side.jpg (43.42 KB)
10864_4b08d4b101d75.jpg 448X336 px
jpg  PB200183.jpg (35.84 KB)
10864_4b08d4d6154a9.jpg 448X336 px
jpg  PB200185.jpg (29.84 KB)
10864_4b08d564d7084.jpg 448X336 px
jpg  PB200187.jpg (34.52 KB)
10864_4b08d58e87c71.jpg 448X336 px
jpg  PB200189.jpg (31.65 KB)
10864_4b08d5a05bd46.jpg 448X336 px
Posted on: 2009/11/22 6:11
Re: cadet 1200 coupe
From SE Melbourne
Red timing cover looks really good, you might have some troubles using an S13 rad with the piping of the plenum.
Got a feeling this car is going to look really good.
Posted on: 2009/11/22 7:24
Mildman, Datsunless
Quite a regular
thanks mate, i have a s13 all alloy radiator but having dramas with it sitting too high (bonnet clearance) and the hose position, so im getting a custom pwr one made! its expensive but this is my dream car so its worth it! will also be able to get the radiator inlet in a decent spot so my engine bay doesnt look like a bowl of spaghetti!
Posted on: 2009/11/22 7:34
From Melbourne, Aus
great looking car, well done. What did you have to do to get the r31 fuel tank to fit?
cheers
Bruce
Posted on: 2009/11/22 9:12
Quite a regular
havnt tried to fit the tank yet,havnt had the time! will have to cut the spare wheel well out and make a flat floor and the rest should be pretty easy, when i do it i will post some pics up! thanks mate..
Posted on: 2009/11/22 9:24
If this is your dream car you are sure doing it justice so far.
Posted on: 2009/11/23 2:05
From Armidale N.S.W
Coming along very nicely. What R31 tank you using ? Wouldn't R31 wagon tank fit without cutting out the 1 inch deep wheel well in the coupe ?. Just a thought we had a wagon one in a bluebird sedan with full size wheel well.
Posted on: 2009/11/23 2:17
73 1200 wagon SOLD
Quite a regular
thanks guys, havnt really looked too much into the fuel tank yet! i have a r31 sedan here thats the only reason i was going to use that tank. thanks for the iomput its great!
Posted on: 2009/11/24 10:15
cadet 1200 coupe
stripped interior.removed tar on floors to check for rust.left tar on tunnel for sound deadning.gave the floor a light coat of tar paint to ensure it is sealed.
Posted on: 2010/1/21 10:51
buy r4 dsi
