« 1 (2)
Re: will A14 head, GX su's, GX exhaust on a A10 work?
Nope.
I thought by you saying, 'more original', you were having trouble trying to pass it via some scrutineer like historic club?
Weber 28/36 DCD using the stock air filter assembly, with the GX exhaust manifold (even the twin pipe KB10 manifold is okay for this) and a slight cam-grind should bring the performance up considerably. But the rock stock KB10 engine (with the high(er) comp A10) is a O-riginal as it gets.
Posted on: 2009/11/22 2:38
I think you are asking a lot of the little A10 with the big-port head and twin carbs, especially if you are intending to run it with the stock A10 cam.
Just to confirm isn't this the A14T head? Aren't the ports on those heads even bigger than the stock A14 oval ports?
Posted on: 2009/11/22 2:45
From Perth WA
seems a great idea to me! that should be good for 9000rpm. they are so undergeared especially on 12" rims that the lack of torque wont matter, would be like a fun big bike engine always wanting more.
Did it end up being seized? Im thinking if it was and needs a rebore u wont be able to use the original flat top pistons.
Posted on: 2009/11/23 5:06
datsun 1000, Its not the size its how u use it.
From Adelaide, Australia
nah bores seemed to be in very good nick. it wouldnt turn round because the head was caked full of loose carbon dust (never seen that b4).
the pistons looked very clean and u can even still see the silver on a couple of the pistons. im just wondering if it even needs a re ring ect.
Posted on: 2009/11/23 5:11
parts needed: GX air filter box. for sale, stanza steering wheel, 1000 gloveboxes lids
oh yea i do need to have it as original as i can to get it historical rego'd. aparently i can modify it to what options were available at that time. i was hoping somewhere in the world they sold 1000's with hitachi su's lol.
considering i have 4 datto's im trying to do one up as original as i can get it so i figured the kb10 would be the best option as i think it will be worth the most in time to come. (maybe im wrong :/).
Posted on: 2009/11/23 5:18
From Perth WA
that was tired when i took it out and then sitting for 10 yrs, i wouldnt trust it to just drop in and drive.
Posted on: 2009/11/23 5:35
From sydney australia
Fitting the GX carbs, especially if they are from another Datsun model, is definitely a period modification, which is what you want. Putting small 12 inch mags should also be allowable. & probably a disc brake conversion, if you could use Datsun 1600 discs & calipers. The only problem I could see with the A14 head would be if it had a larger combustion chamber than the A10, & decreased the compression ratio. Don't forget the nodding dog for the back parcel shelf, that was a popular accessory back then.
Posted on: 2009/11/25 9:56
« 1 (2)
