« 1 2 (3)
Re: Dazza's CA 1200 coupe
From perth
making an adaptor to fit toyota W50 5sp (steel case)
spent 12 hrs measuring both bell housings, clocking in and drilling the dowel holes in the plate
cutting out plate and milling both sides
but its all within 0.001"
nissan just had to make the CA a slant motor!!!!
ended up using the digital read out on the mill to do the angled dowel holes as a pcd
plate milled both sides and drilled for dowel holes. CA separator plate overlaid.note crank CL reference hole
toyota bell housing overlaid
more to come. need to machine dowel holes to finished size. drill and countersink bolt holes.bore starter location hole. grind both sides to finished thickness. bore out hole in centre. lightening holes.
dazza
Posted on: 2009/4/16 13:49
Edited by dazza1200 on 2009/4/17 1:36:58
From perth
looks like i will need to counterbore the centre for flywheel clearance
finished the dowel holes to size. block and bell housing slips over dowels effortlessly.
Posted on: 2009/5/9 6:00
1200 coupe for sale. Free bump
Posted on: 2009/11/24 8:14
From Perth WA AUS
Bump!
Posted on: 2009/11/26 6:46
Datsun 1200 2Dr sedan.
From perth airport
still for sale ?
Posted on: 2009/12/7 4:23
perth airport parking
Datsun 1200 ute A14
« 1 2 (3)
