airbox
Quite a regular
From melbourne
i am looking for an airbox to fit the gx twin su set up if anyone has one laying around they want to get rid of i would be happy to take it off your hands
Posted on: 2003/10/14 14:21
Re: airbox
What do you mean by "airbox"
Posted on: 2003/10/15 2:51
Re: airbox
Quite a regular
From melbourne
by 'airbox' i mean like a air filter box like what it would have come with originally ans bolts to the carbs as i can find heaps on the l series set ups but none for the a series
Posted on: 2003/10/15 14:21
Re: airbox
From Melbourne, Australia
i got dibs on the second one...
Posted on: 2003/10/15 14:25
1200 Coupe Weekender
1200 Coupe Rallycar
1200 Coupe Wife's Daily
1200 Coupe Project A15ETT
Re: airbox
Quite a regular
From melbourne
ha they seem like gold i have been looking for one for a year the trumpets are a bit loud driving every day. i have got some 38mm bits off a l series airbox and am going to make one but thought i would see if there is any around
Posted on: 2003/10/15 14:28
Re: airbox
70coupe12
We call em, an "Air Filter" or air filter assembly. Air cleaner [assembly] is another term.
The bit that strains out the dirt is the air filter "element"
I'l ask about.
Chris
Posted on: 2003/10/15 14:31
Re: airbox
From sydney australia
do you know anyone who is a fabricator,because ol cheap skate me got an oval shaped air cleaner element from finer filter,which was about 100 mm tall,then got a friend who works in the model shop at a leading white goods manufacturer(alright,fridges & washers),to make be a base & a top to suit.this gives enough clearance to use the ram tubes,& looks pretty cool,actually.just use 8mm threaded bar on the two inner bolt holes of the su's to mount the cover.damn,looks like i'll have to fire up the digi camera & takes some photos.
Posted on: 2003/10/16 4:41
Re: airbox
Quite a regular
From melbourne
I recently made an airbox for my twin weber L20b using the airbox and filter out of a 280zx,it sits in the nose of the zx in front of the radiator.You will need to cut the back off it and make a template for it that bolts onto your carbs,also a bracket to support some of it's weight...quite simple really
Posted on: 2003/10/16 13:17
