(1) 2 3 »
Identify these pistons?
From Los Angeles,CA
Can anyone identify these pistons? Are they stock A14's. They are in an A14 block...
jpg  A14Pistons7.jpg (39.22 KB)
8618_4b1e10894e713.jpg 274X433 px
jpg  A14Pistons8.JPG (28.30 KB)
8618_4b1e109c1331b.jpg 445X198 px
Posted on: 2009/12/8 8:40
Re: Identify these pistons?
From Selangor, Malaysia
have no idea what piston is that but i dont think its a stock A14's piston,looking from the piston's dish..
below is the pictures of the piston from my A14..hth
and its pretty look like mine (after the piston been shaved)
Posted on: 2009/12/8 9:15
dying to learn A series..help me :)
From Melbourne, Oz
Pretty sure thats a standard US a14/15 piston. .050" oversize
Edit: seem to remember reading about the dish being diferent somewhere? DD can no doubt shed some light??
Posted on: 2009/12/8 9:21
"I hav achieved wood"
From gold coast QLD.
There the higher comp A14 pistons and the obvious oversize markings.
There getting quite hard to find in Oz but i have one new set
for my next rebuild sitting on the shelf.
Posted on: 2009/12/8 9:23
I will guess they are NOT stock. Stock pistons are not .050 overbore, nor are factory overbore pistons marked 050. Instead they will be 0.5, 1.0 or 1.5 mm overbore.
But they look to have a factory-style dish. I have seen deeper ones, and ones that have an offset dish.
Posted on: 2009/12/8 9:25
Mine are after market DD,i'm not suggesting there genuine Nissan.
You will notice the dish is heaps less than the standard dish
Can't remember the "cc" differance but it's substantial.
Very desirable,so look after them.
Posted on: 2009/12/8 9:35
From Zimbabwe
Those look identical to the ones I have at home except mine are 76mm and are easily available here in Zimbabwe.They are A14 pistons that's for sure.
Posted on: 2009/12/8 9:55
No skool like the old skool
From Los Angeles,CA
The dish seems shallow to me... What is the formula for calculating compression ratio?
Posted on: 2009/12/8 10:57
The formula won't help you. What you need to know is:
1. What is the dish on typical/common A14
2. What is the dish you have?
You can easily get #2. Others here can report #1.
To measure the dish, cut a 1/8 plexiglass to fit over the piston, and drill a small hold towards one side. Then use syringe from a feed store, and see how many CCs it takes to fill the dish.
Posted on: 2009/12/8 11:05
From Townsville, Qld
My pistons have that stupid little key hole that indicates the front of the piston, I'm not a facebook fan of that. I am a fan of the 1 mm dish in them :)
Posted on: 2009/12/8 11:09
(1) 2 3 »
