A12 flywheel unto a A14?
From Nations Capital, Australia
Can a A12 flywheel fit onto a A14 engine without any probs?
Posted on: 2009/12/14 9:57
Re: A12 flywheel unto a A14?
From Melbourne, Oz
so long as its a late a12
Posted on: 2009/12/14 10:06
"I hav achieved wood"
Thank ROConnor.
Is 1980 considered late?
Posted on: 2009/12/14 10:19
From Melbourne, Oz
yes quite late!
edit: mind you I think all flywheels are the same its the thread in the crank that changes, and it changedin 74 I belive.
Posted on: 2009/12/14 10:20
Thanks mate!
Posted on: 2009/12/14 10:22
From Melbourne, Oz
No wories!
Posted on: 2009/12/14 10:23
ALL of the A series flywheels will interchange, however some early 1000 cranks used an Imperial size thread instead of Metric so one would need to ensure that the bolts & cranks matched.
If you have an A14 engine & want to pull the flywheel & simply substitute an A12 flywheel, then go for it.
I used an A10 flywheel on a 1200 crank with flywheel bolts that I found in the grass at a wreckers. It worked for me.
Posted on: 2009/12/14 13:58
Love your Datsun.
Treat it well.
From Snohomish, WA USA
I used my '73 A12 flywheel on my '82 A15 motor for years.
Posted on: 2009/12/14 17:38
'73 2 Door Sedan
Crower Stage 3 Cams/SS Valves
Forge CP Pistons/ Eagle Rods
Ford 8.8/Mini Spool/4.11
