Browsing this Thread:   3 Anonymous Users
how to install the timing chain??
From Invercargill, new zealand
hi
over the weekend ill be assembling my a15 engine, now im not sure how to get the timing chain back on. the a12 i did i replaced the timing chain as it was knackered (engine had nearly 010 of wear - i bet its done a million miles) and the replacement had a joining link but the stock ones dont seem to have that link.
whats the trick to getting the chain on easily when there isnt a removable link?
cheers,
Cameron
Posted on: 2009/12/16 6:41
Re: how to install the timing chain??
A-series chains don't necessarily have a match link. Instead the pullys are marked. As long as you line up the pullys it will be OK.
http://datsun1200.com/modules/mediawi ... ex.php?title=Timing_Chain
Get a manual, a Gregory's or a Haynes or a Nissan factory manual. The bolts need to be torqued specially etc. ... the manual will have complete instructions.
Posted on: 2009/12/16 6:59
so do i take both sprockets off and then loop the chain around them and slide them both back down keeping everything aligned?
Posted on: 2009/12/16 8:26
Not too shy to talk
From Sacramento, CA, USA. Where the tax dollars die.
Posted on: 2009/12/16 15:23
ah thanks, it described the process in the b310 manual. Ive got a 120y workshop manual and official nissan manual for the b110 engine and another for the body but it didnt describe how to do it, its just full of measurements and stuff like that.
Posted on: 2009/12/16 18:56
From Christchurch NZ
The crucial thing is the number of links in the chain between the two dots.
Posted on: 2009/12/17 5:24
Forced Induction!
