GOT IT STARTED -BUT NO SMOOTHING ON IT
From Sri Lanka
Hi Guys
Got my datto started , hope the timing is correct it is getting started at once, just before the start i get a backfire and also id doesn't idle on low rpm ,not at all smooth, i have fixed all vacuum also Any idea Guys ?
Thanks
Regards
sumith
Posted on: 2010/1/1 4:36
Re: GOT IT STARTED -BUT NO SMOOTHING ON IT
Congratulations on getting it started again.
Backfires are usually either too lean (Does your choke works) or timing is incorrect (Do you have a timing light, or can borrow one?)
If it cannot idle, it often is the anti-dieseling valve. Is the wire connected?
Posted on: 2010/1/1 5:24
From hastings,vic
check valve clearences??
Posted on: 2010/1/1 6:31
taking up room at home
hzj75 cruzer tray(for sale)
and allways changing
From Sri Lanka
Hi DD
It doesn't have anti-dieseling valve to the carb ,are intake and exhaust vale clearance differ ? if so what is that, i remember user manual says similar value for both
thanks
regards
sumith
Posted on: 2010/1/4 3:11
Valve clearance for intake & exhaust are the same.
Did you adjust the idle speed & idle mixture?
Posted on: 2010/1/4 3:36
