(1) 2 3 »
A12 & A14/15 Conrod Differences
From Selangor, Malaysia
Hi Guys,
Sorry if this has been asked before, i did search but i didnt get a solid answer for my questions..
my questions is,
what is the differences between A12 & A14/15 conrods?
Can A12 conrod be use with A14 crankshaft?
Many Thanks.
Posted on: 2010/1/7 2:52
dying to learn A series..help me :)
Re: A12 & A14/15 Conrod Differences
From Melbourne, Oz
The can be used on the crank, but the it depends what pistonsand in what block, as the early a12 pistons hav a 17.5mm gudgeon pin, and late a12/14/15 use a 19mm pin, and both early and late a12 use shorter conrods then a14/15's.
So you need the right Pin, crown hight(piston), deck hight(block) and rod length
edit: late a12's may still use 17.5mmpin?
Posted on: 2010/1/7 2:58
"I hav achieved wood"
I'm in a middle of gathering some informations for myself,to put the RB20's piston in A14 block..
so far,what i've found that,in A15 block with A15 conrod,the RB piston will exceed 3mm from the top of the deck..
Is it the same scenario if i'm doing that in A14 block?What if i'm using A12 conrod?
Thanks.
Posted on: 2010/1/7 3:16
From Melbourne, Oz
A14 has same deck hight as a15 so wont change anything.. as for a12 rod's Im not sue of the differance? but I think (verry questionable) they are 3.5mm shorter witch with a light skim of the block would make them perfect.
Posted on: 2010/1/7 3:30
You cannot use A12 conrods to replace A14 or A15 conrods. They are shorter. You can use them with an A14 crank if you want to build a hybrid...
Posted on: 2010/1/7 3:40
From Melbourne, Oz
How much shorter are they?
Posted on: 2010/1/7 3:44
12100-H1000 A12 CONNECTING ROD 121.5mm/4.78" center-to-center
12100-17200 A14/A15 CONNECTING ROD 133mm/5.24" center-to-center
So 0.46 inches difference
Posted on: 2010/1/7 4:02
From St. Louis, MO USA
A12 Conrods are 121.5mm length. Early A12 have 17.4mm pins [part # 12100-H1000]. Later A12A rods are the same 121.5mm length but have 19mm pins [12100-H8500].
A14/15 Conrods are 133mm length and have 19mm pins [12100-H7200].
Posted on: 2010/1/7 4:04
My A14 block has been decked 2.3mm off..so i'm wondering if i'm still able to do the conversions with the block?
i dont think the Rb's piston can be shave 5.3mm the top off..(taking the point from the standard block height with the
A14 conrod)
Posted on: 2010/1/7 4:09
hmm..i think i cant do the conversion with this decked block
Posted on: 2010/1/7 4:12
(1) 2 3 »
