« 1 (2) 3 »
Re: HELP! Need H150A parts / pumpkin
Wrecking yards. They are available up here.
Also, just reported yesterday that pick-n-pull has a 210 in Los Angelese area.
Any B210 1975-1978 or B310 one will fit. Wreckers have warranty too.
You don't even need a mechanic, it's a simple bolt in job, not measuring or adjusting needed.
Some were offered for sale here last month... I recommend that you look instead of your mechanic.
Posted on: 2010/1/7 4:05
From Burbank, CA
sell me one 3.7 h150a / or gears and parts since i already have 2 diffs, and i only need good ring gear and spider, since everything else is new already.
i have $$$
i dont have time to look for stuff.
Posted on: 2010/1/7 4:27
|||\ 81 KPB310 /|||
sell me one 3.7 h150a ... i only need good ring gear and spider, since everything else is new already.
Nissan, give them a call. This is listed in the 2009 catalog although it may have to be ordered and the order may ultimately be canceled by Japan:
38100-H7000 3.700 R&P SET List Price $468.26
My old Nismo catalog says it fits all H150 carriers.
You'll want a set R&P and not fit a used Pinion gear with new Ring gear.
Posted on: 2010/1/7 5:50
Here are the spider gears from Nissan:
38423-H8500 GEAR-side diff bevel (2) $46.40 each
38425-G0300 PINION-mate diff bevel (2) $42.98 each
Likewise these are currently listed as orderable by Nissan USA.
Posted on: 2010/1/7 8:18
From Selah, Washington
I have a NOS 3rd member see my photo album I think they are 3.9's (3.889) though.. make me an offer
Posted on: 2010/1/7 8:36
3.889 will be much better peformance than the 3.700. The latter has a little better fuel economy.
Posted on: 2010/1/7 8:43
From Burbank, CA
i'll figure out what to do about this in the morning... i'll go see if they've had any luck yet. otherwise i'll be buying that shiny nice new one you got there. budget...i probably got about $500 but send me a pm...
Posted on: 2010/1/8 3:44
|||\ 81 KPB310 /|||
You have a Pm...
Posted on: 2010/1/9 5:15
From Los Angeles,CA. USA
What! I can't believe that diff is bad!! Are you sure it's the diff and not the rear wheel bearings? What gear oil are you using?
Bring it back so we can inspect the diff!
Posted on: 2010/1/9 7:01
From Burbank, CA
yay! it's working again, no noise at all...
now i need to get the other things i was fixing back on track now that all the other unexpected things ahve been fixed
thank you all for helping!
BTW ... I'll have a 3.9 h150 rebuilt in the los angeles area if anyone ever needs one in an emergency. yeah that happens often ;)
Posted on: 2010/1/16 3:57
|||\ 81 KPB310 /|||
« 1 (2) 3 »
