« 1 (2) 3 »
Re: Dogleg Trans problem
If it's only there during steady state cruising, and no sound while accelerating or decelerating, it could simply be gear noise. Possibly it won't get any worse, will just be noisy from now on. A former owner may have run it with low gear oil, or fitted a mismatched gear pair.
Unless it is vibrating.
Posted on: 2010/1/10 19:45
From Malaysia
In my case,i heard the sound at normal cruising n accelerating.
But it goes off when decelerating or engine braking..
Posted on: 2010/1/11 1:01
B110 1972 Modded A15
From Freo
front Bearing.. loaded up when Accel, no load on decell, or in 4th.
Posted on: 2010/1/11 1:48
A15 PSI Project Motor
'72 CB750k,
From Malaysia
But im wondering tat if is a bearing sound it should be heard all the time,rite??
Posted on: 2010/1/11 1:57
From Melbourne, Oz
Nah not realy, beacause as the load increases it gets louder to the point where you can here it through the thick alloy case and trans tunnel.
Posted on: 2010/1/11 2:09
"I hav achieved wood"
From Toowoomba, Qld
When your accelerating, the countershaft and main shaft are trying to move away from each other under considerable force, alot more force than decel/cruise. When in 4th gear, the input shaft and main shaft are locked together, the bearing in between should be stationary,(no noise). In all other gears, the bearing is turning, as the input/output speeds are different, (when you have noise).
Cheers
Dave.
Posted on: 2010/1/11 4:57
From gold coast QLD.
Geez,just put a set of bearings thru it before something goes BANG!!
It,s not an expensive exercise.
Posted on: 2010/1/11 5:39
From Selah, Washington
"Geez,just put a set of bearings thru it before something goes BANG!!
It,s not an expensive exercise."
UNTIL IT GOES BANG!
Posted on: 2010/1/11 6:04
From Malaysia
Haha...
Thanks...
I need to lower the engine crossmember juz to take out the trans...
Cant do it at my home so i need to send to my frens workshop which cost more...
BTW can i swap the gear set from 60A to my 60L??
Posted on: 2010/1/12 4:41
From Freo
no you can't
Posted on: 2010/1/12 4:43
'72 CB750k,
« 1 (2) 3 »
