sunny struts
From sutho shire
hay just wanna no if the sunny struts bolt straight into the ute's?
Posted on: 2003/10/26 11:56
*1200 ute ca18det (CYA-18T)
256 rwhp at 14psi wanting more power
Team New skool
Re: sunny struts
From Newscastle, Australia
They should....as I have a Sunny and a 1200 and have compared struts. The only thing is the Sunny disc brakes are too small for anything other than stock A12 power. You may want to put 200B GX discs and the alloy girlock calipers which fit straight on. By the way the 310 Sunny shares exactly the same underpinnings as the Stanza.
Posted on: 2003/10/26 20:25
Re: sunny struts
From Melbourne, Australia
the sunny gear is the same as the round headlight stanza, the square headlight stanza has better stuff
Posted on: 2003/10/27 0:11
1200 Coupe Weekender
1200 Coupe Rallycar
1200 Coupe Wife's Daily
1200 Coupe Project A15ETT
Re: sunny struts
From sutho shire
i thought i better ask before installing them ...
Posted on: 2003/10/27 2:37
Team New skool
Re: sunny struts
From Pakistan
one more Q:
r OEM B-310 Struts Front and Rear any better them 1200 OEM's?(spring rate and/or durability better)
both direct swap or not?
Posted on: 2003/10/27 13:00
STRONG IS STRONGEST ALONE. PERIOD
Re: sunny struts
From Pakistan
BUMP for the answers........
Posted on: 2003/10/28 19:39
