Datsss wrote:
Yeah I,m sure a ca or sr will have heaps of h/p and be great to drive, but it depends on what your trying to do with your car. Yes my car is an a series, it will have better weight dispersment and will corner better than a ca powered car and therefor will be faster.
dont really agree with that, with a CA you also have a larger gearbox in the middle of the car and a larger diff in the rear. so the weight balance would probably be pretty much the same
and the CA powered car will probably have bigger brakes so coule come up to the corner faster and still be able to slow down to a speed at which it could get around the corner
then it would make its way away from the corner a whole heap faster then the a series car
if your wanting the car to be fast roud corners id say your time would be much better spent one suspention work and brakes than it would trying to save some weight
