(1) 2 3 »
A14 HP
From mandurah
hey everyone just wondering what HP i can expect out of an A14 with a holly ,cam , extractors and a 1and 3 quater inch zorst system
i know there are so many variables but i just want a pall park of what can be achieved with an A14
cheers
Posted on: 2010/1/21 9:05
Re: A14 HP
From Perth
what and why a holley ?
what cam ?
why such a small exhaust ?
Posted on: 2010/1/21 10:53
Re: A14 HP
From Townsville, Qld
I 1 3\4 is the outlet size of the A14\15 manifold. I ran that size and with a pretty punchy cam and 32\36 weber and I'd say it was probly making about 85-90hp tops considering the condition of the engine at the time. When I finish with the rebuild (which should be early next week) I'll be looking for 100hp and if I don't find it I'm gonna throw some angry marks on the nearest drag strip....then again I'll throw some patches on said drag strip if I do make that:P
I'll write up the specs later when I have it running.
Posted on: 2010/1/21 13:03
Re: A14 HP
I'd say 85 HP at the flywheel. The stock A14 head won't flow 100HP.
Posted on: 2010/1/22 2:31
Re: A14 HP
From mandurah
hey its webber copy and how can i get around a 100 horse out of an A14
im getting it rebuilt so i need to know what will need to be done to get some decent HP
cheers
Posted on: 2010/1/22 4:14
77 1200 ute
77mm bore a15 ,12:1 comp
ported and reconed h89 head
MSD 6al2 with 2 step limiter
4speed 60a box
hd clutch
2 inch exhaust
locked 4:11 ute diff
Re: A14 HP
From Perth WA AUS
You can buy my h89 head!
Posted on: 2010/1/22 4:39
Datsun 1200 2Dr sedan.
Re: A14 HP
Yes, for 100HP get an H89 head, have it professionally ported, fit with aftermarket valves springs, install a high RPM camshaft, use 40mm carburetors and a 2" exhaust system from head to tail.
So maybe $4000.
Or you could swap in a good used L20B four cylinder, for $400 and a case of VB for your friends who do all the work.
Posted on: 2010/1/22 7:17
Re: A14 HP
From Brisbane
i have a 320 holley on my a12 with a drawthrough supercharger, oval port head not sure what type but i got 100hp at the flywheel n 80 rwhp custom extractors n 2 inch exhaust
Posted on: 2010/1/22 7:34
Re: A14 HP
Yes, that's another great way to get 100HP through the A-series cylinder head: Forced Induction. It can even be less expensive than the high-RPM naturally aspirated method, depending on how you do it or what kind of deals you can make.
Posted on: 2010/1/22 7:39
Re: A14 HP
From Perth WA AUS
Hahaha VB? Was that a wise crack DD? :)
Posted on: 2010/1/22 7:59
(1) 2 3 »
