« 1 (2)
Re: What gearbox is this?
From Perth WA
afaik the 1000 coupe gearboxes dont have 56a on it, even if it is a 56a, maybe some did and some didnt.
one of mine that came out of a 180B / 610 with the clutch lever higher up has 56a on it, even more confusing.
Posted on: 2010/2/2 10:06
datsun 1000, Its not the size its how u use it.
From gold coast QLD.
I can assure you all this is not a B10 box!They all used the cable to a shaft operation to operate clutch actuation.
Having said that,i too have yet to see a "smooth case 56A" box.
Who'd be an early Nissan parts interperator!!!
Posted on: 2010/2/2 10:22
From Freo
I'm with Bert, all the 1000's had the Shaft to cable setup..
not cable onto the fork..
Posted on: 2010/2/2 11:21
A15 PSI Project Motor
'72 CB750k,
From mandurah
for sale 1 smooth case 56A gear box (with chrome gear knob) will swap for some GX Valve springs (levey)
Posted on: 2010/2/2 13:23
77 1200 ute
77mm bore a15 ,12:1 comp
ported and reconed h89 head
MSD 6al2 with 2 step limiter
4speed 60a box
hd clutch
2 inch exhaust
locked 4:11 ute diff
Datsun 1000 gearboxx
The smooth one has a different tail casting too there is a rectangular bit on top that the others don't have.
The 1000 & 1200 56s have ribbing all round, while the newer 1200 utes have even more ribbing, and thicker ribbing. This suggests even the regular one was found to be not strong enough (as they strengthened it).
Posted on: 2010/2/3 4:29
From Perth WA AUS
Sold!
Posted on: 2010/2/3 7:32
Datsun 1200 2Dr sedan.
From mandurah
het are these gearboxs stronger than a standaed 1200 box?
Posted on: 2010/2/4 4:34
77 1200 ute
4speed 60a box
hd clutch
2 inch exhaust
We have been discussing how they are less strong than the standard gearbox.
Posted on: 2010/2/4 5:02
« 1 (2)
