Need Help...Timing Chain Alignment
From Selangor, Malaysia
Hi guys,
Need your help here..i'm trying to do the timing chain alignment to my A14,referring to this one:-
unfortunately,it don't work like the manual said..
when i turn the crankshaft (referring to the above picture)i can't get TDC (it will be ATDC) for piston #1 and same goes to camshaft,when i try to turn it (as in the picture)the #1 intake's push rod already pushing,i guess it will not supposed to be like that,isn't it where can it be wrong?
below is the picture of what i've done best for today,i've turn the crankshaft to get the TDC for piston #1..
Please help me..
Many Thanks..
Posted on: 2010/2/6 14:46
dying to learn A series..help me :)
Re: Need Help...Timing Chain Alignment
Yes those instructions sound wrong. At TDC, the crank won't line up as shown in the photo.
Use the procedure listed in your repair manual. Sometimes a new chain will also come with instructions.
Also be sure to check the sprocket height and put the correct shims in, per the repair manual.
Posted on: 2010/2/6 19:06
From Christchurch NZ
Also coungt the number of links in the chain between the marks. thats an important part of it.
Posted on: 2010/2/6 23:46
Forced Induction!
From Townsville, Qld
I spent a couple of hours doing this just recently and I ended up sticking a couple of pushrods in to see the elevation while I tried what I thought was the correct mark. I don't think it would have taken me so long with a standard cam. I think I ended up counting nine links between match marks (chain wasn't helpful in that regard it's got stampings all over the joint at 4,9 links etc
Posted on: 2010/2/7 1:48
From SE Melbourne
You should be able to see the marks on my chain here...
Posted on: 2010/2/7 1:54
Mildman, Datsunless
Yes, the marks on the links do not matter. If you have the shafts lined up correctly and count of the 9 links, you are good to go.
Posted on: 2010/2/7 2:09
From perth
screwdriver in #1 check tdc
#4 on rock
done
Posted on: 2010/2/7 6:01
thanks guys,
mildman : thanks for the picture
so now,i need to be completely sure on #1 TDC and #4 on rock..
i really2 love datsun1200..yay!!
thank you so much!
Posted on: 2010/2/7 7:08
hi guys,i have question regarding this timing chain alignment manual..the above manual's picture is for Nissan A series from what year to what year does it applies to?
Posted on: 2010/2/8 2:56
It applies from 1966 to 2009 A-series engines.
Posted on: 2010/2/8 3:47
