For Sale - Supercharged A15 complete setup from radiator to diff
From sydney
I started a new thread as I have just bought a CA18det runner. I would like move this on so I can get work started and need the funds. New pics taken tonight. Thanks Gav, I owe you one.
*Engine rebuild only 5000km's
new oil pump
new water pump
new chain and tensioner
fully balanced from blower pulley to clutch
bored 40 thou
ga16 n14 pulsar acl pistons (sit lower in bore for decomp)
1mm acl decompression plate
jts blower cam
mild port head
match ported inlet manifold
arp head studs
*jts extractors 4/2/1
*2 1/4 inch exhaust with 3 inch crome dumpy to suit coupe
*SC14 charger
*billet pulleys makes 16psi in top gear at 6200rpm 12psi in lower gears
*350 holley
*Big alternator (chev)
*electronic dizzy and bosch coil (e15)
*snow performance boost cooler water/menthanol injection with hop switch that turns on at 5 psi
*N13 pulsar radiator with 2 thermo fans
*jts supplied clutch
*standard 4 speed
*120y locked BW diff
Complete supercharged A15 in car and running. You can come and test drive before you buy. Drives beautiful and starts first go. Never been on dyno, was only road tuned by myself with O2 sensor and air/fuel ratio meter. Only ever done 2 pases with best of 14.6 as it was leaning out at top end of the track (needs bigger fuel pump). Much more potential with bigger pump and dyno tune but ive been driving for a while as is. I love this engine but only selling to fund CA project.
Please only call if you intend to buy. If you are just after info im happy to answer PM's. Photos up soon
$2600 all reasonable offers considered
Josh
0405142762
methonal injection
Posted on: 2010/2/8 11:22
Re: For Sale - Supercharged A15 complete setup from radiator to diff
From Sydney
No worries mate, since you offered i might need a favour soon.
Posted on: 2010/2/8 11:27
Not too shy to talk
Ashame to see that you are going the way of the masses with the ca18det conversion but I can say whoever buys this setup will not be disappointed it is alot of fun to drive heaps of power
good luck with the sale
Posted on: 2010/2/10 4:10
From Sydney
Hey mate, just wondering what car you have this in?
Posted on: 2010/2/10 12:03
From sydney
1200 coupe dude
Posted on: 2010/2/10 21:55
From sydney
Bump need it gone.Open to reasonable offers
Posted on: 2010/2/18 8:49
From Coondle, WA Australia
ts a pity its in a 1200. If it was in a 1K, then I would probally jump at it. I know that I could take off the bits that dont fit, bu that just leaves the block, so its kinda pointless.
Bugger....
Posted on: 2010/2/18 8:58
EARTH FIRST! - We can mine the other planets later...'
'69 Blue 4 door Project Daisy (http://www.datsun1000.com/TopicView.asp?TopicID=668)
(https://pcmhacking.net/forums/viewtopic.php?f=15&t=5640)
(http://mx5cartalk.com/forum/viewtopic.php...
Not too shy to talk
From canberra
would this bolt staright into a 1200 ute ?
Posted on: 2010/2/18 10:53
From sydney
Pretty much there are a couple of things that would need to be done a weekends work and it would be driving
Posted on: 2010/2/19 8:33
From Freo
come on Reuby.. u know you can make it happen..
Posted on: 2010/2/20 1:48
A15 PSI Project Motor
'72 CB750k,
