Short A14 twin carb manifold???????
From Tasmania
Is there such a thing as a short twin carb manifold for the A14 that will mount twin 40mm carbs??? I have a GX twin carb manifold but once the carbs are mounted I only have 40mm clearance between the carbie faces (No trumpets) and the fire wall.This is in my E10 Cherry.
Posted on: 2010/2/12 2:57
Proud member of " The Tasmanian Datsun Owners Group"
Re: Short A14 twin carb manifold???????
From Perth WA AUS
Sounds like a custom job to me.
Posted on: 2010/2/13 8:11
Datsun 1200 2Dr sedan.
From Tasmania
I was thinking that.
Posted on: 2010/2/13 14:22
From Las Vegas USA
There is a short"er" manifolds for single DCOE but I think you guys are corrrect on the GX manifold nedding to be custom. Will this be a street car??? If not several FWD race cars back in the day had the velocity stacks extending through the firewall into the passenger compartment, using the proper gauge sheet metal to form an airbox and then pull air in though the vent......or not!!!
Tom
Posted on: 2010/2/13 20:21
From Tasmania
Rallytwit: she is to be a racer and that is one one of modifing it I have thought of that or a big bonnet sccop with a large panel filter feeding down to the Carbs. I also may just make a thin box with a 2-3 inch pipe on the end and cold feed from a pod filter mounted down the front of the car.
Posted on: 2010/2/19 9:36
From Perth WA AUS
Why not cut an inch or so out of the middle of a standard manifold and weld it back together?
Posted on: 2010/2/19 11:01
From Townsville, Qld
You could also angle the manifold up by machining the mounting face. The firewall technique is mention in the how to race your datsun book, it says you could draw cool air from the waterbox section of the firewall where it has the added benifit of being a high pressure zone on the car away from dust.
Posted on: 2010/2/20 13:44
From Tasmania
have also thought of doing that I will try and get a pic up once I get home will be a bit busy with Rally Tas these days off.
Posted on: 2010/2/23 23:20
From Tasmania
heres a pic of the gap I have to play with.
Posted on: 2010/2/25 2:53
From Perth WA AUS
Oh, thats not much room!
Posted on: 2010/2/25 9:01
