Re: datsun
From SE Melbourne
So you are going to leave the oem struts in there, with the original brakes too?
Posted on: 2003/11/2 23:32
Mildman, Datsunless
Re: datsun
From Perth W.A
if you are going to go to that trouble go the whole hog and get a side on write of series 2 VS with a 3.8 supercharged V6 ecotec then use the diff gbox and the IRS and then you will have a cool car !!!! cos you can then say you have a buick based datsun and not a common hore
Posted on: 2003/11/3 2:41
120y Coupe
120Y coupe Race car (SOON)
120Y Sedan for the Lady
Re: datsun
i want 2 put a skyline dif and disc brakes
Posted on: 2003/11/3 10:45
Re: datsun
From Canberra, Australia
Doesn't the newcastle rod shop or something like that do kits for this?
The same guys who do the V8 Gemini conversion type things.
I'm not sure though.
Posted on: 2003/11/3 12:08
1971 Datsun 1200 Coupe
A15 Engine. Holley G180 (32/36 Weber). extractors and 2 inch exhaust.
Standard 1200 4 speed with lightened fly wheel and HD clutch
Stanza front struts and brakes.
15x6 CSA Wheels with 195/50 rubber.
Re: datsun
From Millgrove Vic OZ
Mildman,
Sub 2 minutes at the island isnt too hot.-
A good stock A12 310 can do that with good handling and brakes.
Craig Watson( X 4+ Performance 1994) PIARC meeting).
Posted on: 2003/11/3 14:00
Cheers Feral
Re: datsun
From SE Melbourne
I actually went and checked his times, best lap at the August PIARC round was 1:49.55.
Now that is a fast time, in fact that second fastest time outright for the event.
If you've got a stocker that can break 2min, you would win best in class by around 12.5 seconds in the under 1600cc standard car class. The current fastest time is held by a Corolla SX 1.6L at 2:12.15
But with upgraded suspension and brakes you might be into modified car class, then you've got to beat 1:55.74
I'm still impressed with anyone who can run under 2min at the Island it is the respect time there, much like 1:30 at Sandown is deserving of respect.
Posted on: 2003/11/3 23:53
Mildman, Datsunless
Re: datsun
From Adelaide, Aust
Is there much size difference between the holden V6 and a non turbo VG30 cause imstill debating what engine to fit in sedan and the VG was an option.
Posted on: 2003/11/4 10:20
« 1 (2)
