building supercharged a15 *HELP*
i just blew my head on my 1200 coupe, just been waiting for it to happen, now i need to build my a15 for the supercharged setup.
as the title states i need to no wat ppl would reconmmend that i should do to it to handel 10psi??
dont want to spend too much as trying to save for ca but i want something half good that will be fun while i wait for the ca to be built.
any ideas would be good.
i have an open chamber head off a vanette to go on the motor to so have to take that into account too.
cheers nick
Posted on: 2010/2/22 9:51
Edited by supafatto on 2010/2/22 10:25:17
Car free
Re: building supercharged a15 *HELP*
For 10 PSI, you need do nothing to the block. Use the stock crank, rods and pistons and camshaft.
No mods are needed to the head either.
Save your money and invest in a good intercoolor system. You don't need an intercooler, but that's where your biggest power gains will come from.
Posted on: 2010/2/22 21:41
i dont think he can go intercooler with the sc set up he has, so just set up the water/meth spray like you were going to
Posted on: 2010/2/22 22:48
From Ballarat Victoria
Keep it all standard inc compression ratio.Intercool if possible and spend the money saved on parts on a GOOD dyno tune.
You wont need an intercooler if you are using a screw type blower but i would recomend one if you are using a rootes type and running over 7 Psi.
Posted on: 2010/2/22 23:15
VIC DYNO HIRE
From sydney
Ga16 pistons head studs and water/meth and she will be apples on 10psi
Posted on: 2010/2/22 23:55
From Christchurch NZ
I roll with a head save shim. works for me. A lumpy cam with a wider lode sepaeration angle wont hurt either.
Posted on: 2010/2/23 5:33
Forced Induction!
bump, going to talk to tomoz on sat about the build
Posted on: 2010/2/24 8:54
Car free
A14Force, for 10psi you run a head shim? Seems unnecessary.
Posted on: 2010/2/25 1:13
ok so i pulled my a15 apart on the weekend to find the block is as stock as a rock, so good starting point.
i have an open chamber head to put on it and would like to no wat sort of compression ppl are running wit 10psi so i can sort some pistons as i have to hone the boars at least 1mm as there is alot of pitting in them.
also can anyone reccomend a good type of cam to run for this setup.
thinking of staying old skool and just building a sic motor and stay wit that rather than going ca so i want to do all the hard work now.
gonna get it all balenced from fly to sc pulley.
anything else i should do while i got it cracked open??
thanks for the input nick :)
Posted on: 2010/2/28 10:38
Car free
For 10 psi w/intercoolor use the stock compression ratio.
Use a cam with wide lobe separation. Tell you cam company the RPMs you want to run and they'll select the best cam for you.
Posted on: 2010/2/28 20:22
