160j PA10 axle
From Kuala Lumpur, Malaysia
hey guys...need some help here....
can i install/swap 160j PA10 axle into a B310?? plug and play or need some modification??
what about the ratio different?? PA10 vs B310??
thanx and much appreciated...
Posted on: 2010/3/10 9:30
Re: 160j PA10 axle
From Townsville, Qld
If memory serves me right B310 is equipped with a H150 whereas the PA10 is using a H165. Not sure about the trailing arm positioning between the two models but a mechanic friend once told me a B310 Sunny was "basically" just an A series powered Stanza. Sunny on here has some stanza parts lying around as well as a Sunny so I could go find out tomorro
Posted on: 2010/3/10 12:37
Re: 160j PA10 axle
many thanx....need input ASAP as project still on hold....
anyone else can help me here??? anyone??
Posted on: 2010/3/10 16:12
Face Your Demons
Re: 160j PA10 axle
From Christchurch NZ
I heard somewhere that they do fit, But as we got almost no A10's here (But we did get the 710's) I can say for 100% sure. I do know that you'l need to have your driveshaft shortened as the H165 centre is a bit longer.
Posted on: 2010/3/10 20:42
Forced Induction!
Re: 160j PA10 axle
bring up my post!!
Posted on: 2010/3/11 11:31
Face Your Demons
Re: 160j PA10 axle
maybe ask at ozdat?
Posted on: 2010/3/12 5:39
Forced Induction!
Re: 160j PA10 axle
hurmm....thanx all for the info....much appreciated!!
Posted on: 2010/3/12 7:47
Face Your Demons
Re: 160j PA10 axle
anyone else here have any input for me??
Posted on: 2010/3/13 15:50
Face Your Demons
Re: 160j PA10 axle
A10 and B310 are the same chassis.
B310 had smaller engines, transmission and rear axle
A10 had larger engines, transmission and rear axle
Likely it will fit without any substantial modification. But no one has tried it.
Posted on: 2010/3/13 20:14
Re: 160j PA10 axle
From T'ville
nisssan a10 stanza diff will bolt straight into b310 chassis a10 diff is about 30mm wider over all. you will need to make the tailshaft/drive shaft fit, what sort of engine do you have? the h150 will take alot of abuse but needs good oil in it.i have put one in my b310 but now think i need a h190.
Posted on: 2010/3/13 20:29
